Inert gas as a cover
Posted: Wed Jun 06, 2012 3:39 am
If using an inert gas as a cover, do you just squirt the gas into the crucible, plus as it heats up does the gas rise out of the crucible
The Foundrymans Resource
http://founddreaming.com/metal_casting/forum/phpBB3/
http://founddreaming.com/metal_casting/forum/phpBB3/viewtopic.php?f=10&t=347
Thanks Jammer, I was going to try just for an experiment to see how well it would workJammer wrote:A lot would probably depend on how much turbulence you have inside the furnace. An electric wouldn't have much but a forced air gas burner would blow all the gas out the top. A small tube feeding the gas in at a slow rate would help, but then you have to worry about the tube melting.
