syphon burner I been working on
The Heat is ON in Here.
Re: syphon burner I been working on
The burner that I posted about a couple weeks ago that I was building for a guy in Tulsa, heres the results of that.
http://www.youtube.com/watch?v=BQXJLi82wkI
hope to put it on oil next weekend once the top of the furnace is completed.
furnace construction is fiber 8 LB/foot and 2600 degree fire brick, furnace heats up like really fast, as you can see from the video the furnace is made for a lot larger crucible then an A10, with the larger crucible in it there will be a lot better use of the heat and with a top that has a lot smaller exhaust opening then just covering half of the top with some fiber.
really nice furnace.
That's the Guy who builds subs, I've been looking at his site a few times. I like some of the stuff he does. I used to do a lot of diving and even built a sub once many years ago. It was a wet sub and didn't work very well, always wanted to rebuild it and fix some of the problems, many it was way too long. It was fun but I was young and stupid. I don't even know where it is now.
he's not building a sub now this is for on the water not under it.
Great looking burner David, wish mine looked half as nice but I sure cant complain about how it works. Been really putting it through its paces this last week and loving every minute of the dual fuel setup, tunes so easily and burns so clean. Before I would sometimes get an oily taste in my nose/mouth but have not had that since adding the propane. Amazes me at how big of an improvement it makes for so little propane used.
