Page 1 of 3
My waste oil Burner
Posted: Sun Nov 27, 2011 9:22 pm
We'll the wheels of progress sometimes move rather slow here but I've finely completed my waste oil burner and tank storage. Hasn't been test fired yet as I'm looking after our two granddaughter and its not the thing that I want to be playing with while they're around
http://www.youtube.com/watch?v=_COc7hFK8Q8
Re: My Burner
Posted: Sun Nov 27, 2011 10:11 pm
Looks good Mike, pressurized tank? Nice filter setup.
One thing you might want to look for is some fine control valves. Oil burners go from intense to crazy with the slightest crack of a ball valve.
Re: My Burner
Posted: Sun Nov 27, 2011 10:46 pm
Harry wrote:Looks good Mike, pressurized tank? Nice filter setup.
Yes Harry a pressurised tank I'm using a delavan nozzle and apparently they need about 80 psi to vaporise the oil so I though pressuring the tank would be the easiest way to do it. what type of fine control valves do you mean Harry
Re: My wasre oil Burner
Posted: Sun Nov 27, 2011 10:50 pm
And that filter system will be changed, when I ordered it I though the oil would flow through one filter then the other, it flows through both at the same time, not what I wanted. I will end up with a system were I'll have oil going through one filter then the other to hopefully remove any crap that gets through the first
Posted: Mon Nov 28, 2011 5:11 am
Mike click on the quote button after reading what I typed below on the first sentence
Posted: Mon Nov 28, 2011 11:11 am
I bought a couple of
these valves recently Mike. Have yet to use them but they seem to provide very fine adjustment.
Not sure what you will be able to do about adjustment with the standard pressurized nozzle setup as they need a certain amount of pressure to atomize properly. You might be able to get all of the adjustment available using air pressure. From what I understand that type of nozzle is either full on or off but then that is when using them in the beckett style home heating units where the oil pressure is not easily adjustable like your air setup will be. With the siphon nozzle like I use you can feed any amount of oil and it is atomized by the air stream so it always atomizes regardless of flow volume.
Also since I now realize what kind of setup this is, how much pressure are those oil filters/seals good for?
Posted: Tue Nov 29, 2011 2:59 am
Thanks Dave I'll give that a try next time
Harry I'll see how I go with the system that I have, if I have any issues I'll post them and I'm sure there will be heaps of constructive help, with regards to the filter seals taking the pressure I hope to find out on Thursday
, wife sure will be pissed if I spray oil everywhere
Posted: Tue Nov 29, 2011 9:00 am
Mike I don't know what type nozzle you have but the regular fuel nozzles that I used to work with in small oil heaters will turn down but your going to need a constant supply of oil to them to make it work. normally the lowest we would turn them down was around 70 to 90 pounds but we were also putting a lot of air into the system with large blower cages on the motors.
Give it a try if possible video it so if you have problems we can see those also, lots easier to help if the problem can be seen, also the hard data, IE fuel type, fuel pressure, air pressure, or air source. all these are important to knowing what is happening.
Oh yea find a barrel to spray it into so the wife don't get PO'ed
Posted: Wed Nov 30, 2011 9:01 pm
Welll I had a bit of a trial on my burner today and it was not much of a success, I'm having some problems with getting enough pressure to atomise the oil, all I can get in the storage tank is about 70 psi, I'm on night shift to night so its going to have to wait till I come off shift
Posted: Thu Dec 01, 2011 12:19 am
Maybe I should use one of these instead of using the compressor
http://www.ebay.com.au/itm/WEBSTER-M34D ... 1c1d9fa45a
