Composition of Metals
Melting Points, Pouring Tips and Properties... Metal is the Foundries Lifeblood.
This is a list of alloys from the other site. It hadn't tranferred and I'm afraid it will be lost. I don't have most of the list myself. Until now.
This is a post where I will try to put all the alloys, so we won't have to hunt through the whole thread for something.
Non-Ferrous Alloys
Ampco A18 Aluminum Bronze
Al - 8.4%
Fe - 3.75%
Mg - 0.7%
Mn - 0.1%
Cu - 86.4%
Brass Round Stock
Cu - 54.5%
Zn - 41.7%
Sn - .22%
Pb - 2.9%
Brass Round stock #2
Cu - 76.4%
Zn - 4.6%
Sn - 9.9%
Pb - 6.4%
P - 1.2%
Brass Propand tank valve, Sherwood
Cu - 54.6%
Zn - 42%
Pb - 2.1%
Brass Ball Valve, Apollo USA
Cu - 75.6%
Zn - 11.6%
Sn - 5.1%
Pb - 5.3%
P -0.7 %
95/5 Solder, Lead Free
Sn : 97%
Sb : 2.6%
a few trace elements.
#1 Aluminum Wheel Alloy
Al - 91%
Si - 8.5%
Fe - .42% (questionable)
#2 Aluminum gas Grill Alloy
Al - 80.5%
Si - 15.6%
Cu - 2.4%
Zn - .80%
Fe - .88% ??
Aluminum Pop Can
96% Aluminum
1.6 to 2% Si
.8 Mn
.3 Cu and Zn
Posted: Fri Jan 28, 2011 1:40 pm Post subject:
by Chingon
Piston alloys:
2618:
from matweb:
http://www.matweb.com/search/DataSheet. ... T61&ckck=1
Aluminum, Al 92.4 - 94.9 % As remainder
Copper, Cu 1.90 - 2.70 %
Iron, Fe 0.90 - 1.30 %
Magnesium, Mg 1.30 - 1.80 %
Nickel, Ni 0.90 - 1.20 %
Other, each <= 0.050 %
Other, total <= 0.15 %
Silicon, Si 0.10 - 0.25 %
Titanium, Ti 0.040 - 0.10 %
Zinc, Zn <= 0.10 %
4032:
http://www.matweb.com/search/DataSheet. ... 324e592396
Aluminum, Al 81.1 - 87.2 % As remainder
Chromium, Cr <= 0.10 %
Copper, Cu 0.50 - 1.30 %
Iron, Fe <= 1.0 %
Magnesium, Mg 0.80 - 1.30 %
Nickel, Ni 0.50 - 1.30 %
Silicon, Si 11.0 - 13.5 %
Zinc, Zn <= 0.25 %
from nasioc:
-- 2618 conducts 6% more heat, which is good for keeping the piston cool under high-load, but bad for keeping combustion warm under low-load. Because a 2618 piston will be a little cooler, it may not need the full 15% greater clearance compared to an otherwise identical 4032 piston, which would be hotter under the same load.
-- 4032 is 4% harder and has a 6% higher modulus of elasticity, which is probably at least partly responsible for its superior wear characteristics.
-- 4032 is 3% lighter, which somewhat offsets its reduced strength.
-- Per square inch, 2618 has only 13% greater fatigue strength, even though the ultimate strength is 16% higher and the 0.02% yeild strength is 17% higher. (The fatigue strength is the most important one for a daily driver.)
-- Per pound, 2618 has only a 9.5% greater fatigue strength instead of 13%, and only a 13%, instead of 16%, higher ultimate strength.
On cast alloys (good wiki compilation on identification of al-alloys:
http://en.wikipedia.org/wiki/Aluminium_ ... ast_alloys
On Al-Si alloys:
http://www.keytometals.com/Article80.htm
Posted: Fri Jan 28, 2011 1:53 pm Post subject: By Chingon
GMC block alloys (for current vehicles):
242-t77:
http://www.matweb.com/search/DataSheet. ... 7c67199cc2
Aluminum, Al 88.3 - 93.6 % As remainder
Chromium, Cr <= 0.25 %
Copper, Cu 3.50 - 4.50 %
Iron, Fe <= 1.0 %
Magnesium, Mg 1.20 - 1.80 %
Manganese, Mn <= 0.35 %
Nickel, Ni 1.70 - 2.30 %
Silicon, Si <= 0.70 %
Titanium, Ti <= 0.25 %
Zinc, Zn <= 0.35 %
319-t5
http://www.matweb.com/search/DataSheet. ... e187be6e63
Aluminum, Al 85.8 - 91.5 % As remainder
Copper, Cu 3.0 - 4.0 %
Iron, Fe <= 1.0 %
Magnesium, Mg <= 0.10 %
Manganese, Mn <= 0.50 %
Nickel, Ni <= 0.35 %
Other, total <= 0.50 %
Silicon, Si 5.50 - 6.50 %
Zinc, Zn <= 1.0 %
A356-t6
http://www.matweb.com/search/DataSheet. ... bd1c7ed070
Aluminum, Al 91.1 - 93.3 % As remainder
Copper, Cu <= 0.20 %
Iron, Fe <= 0.20 %
Magnesium, Mg 0.25 - 0.45 %
Manganese, Mn <= 0.10 %
Silicon, Si 6.50 - 7.50 %
Titanium, Ti <= 0.20 %
Zinc, Zn <= 0.10 %
Ferrous Alloys
Rail anchor ("clip"): C: 0.51 | Mn: 0.80 | P: 0.01 | S: 0.03 | Si: 0.18 | Cu: 0.24 | Cr: 0.07 | Mo: 0.02 | Ni: 0.07 | Sn: 0.010 | V: 0.002 | Cb/Nb: 0.015
Bed frame angle iron: C: 0.53 | Mn: 0.83 | P: 0.02 | S: 0.02 | Si: 0.19 | Cu: 0.01 | Cr: 0.02 | Mo: 0.005 | Ni: 0.01 | Sn: 0.006 | V: 0.002 | Cb/NB: 0.002
Demolition hammer bit: C: 0.42 | Mn: 0.70 | P: 0.005 | S: 0.02 | Si: 0.2 | Cu: 0.02 | Cr: 0.02 | Mo: 0.005 | Ni: 0.02 | Sn: 0.004 | V: 0.0 | Cb/NB: 0.002
Tire iron: C: 0.70 | Mn: 0.75 | P:0.01 | S: 0.01 | Si: 0.23 | Cu: 0.01 | Cr: 0.01 | Mo: 0.002 | Ni: 0.0 | Sn: 0.0 | V: 0.001 | Cb/Nb: 0.0
Torsion bar off a Ford pickup: C:0.60 | Mn:0.85 | P:0.030 | S:0.025 | Si:0.28 | Cu:0.01 | Cr:0.80 | Mo:0.02 | Ni:0.01 | Sn:0.01 | V:0.008
Cheapo, made-in-India, Harbor Freight bastard file: C:1.3 | Mn: 0.34 | P:0.015 | S:0.009 | Si:0.24 | Cu:0.01 | Cr:0.62 | Mo:0.005 | Ni:0.02 | Sn: 0.003 | V: - | Nb:0.010
Old, Nicholson mill bastard file: C:1.28 | Mn:0.34 | P: 0.016 | S:0.015 | Si:0.15 | Cu: 0.02 | Cr:0.14 | Mo:0.005 | Ni: 0.02 | Sn: 0.002 | V: - | Nb: -
Old, American-made (Heller brand) mill bastard file: C:1.20 | Mn:0.25 | P:0.010 | S:0.020 | Si:0.12 | Cu:0.04 | Cr:0.03 | Mo: 0.004 | Ni:0.03 | Sn:0.018 | V: 0.005 | Nb: -
Railroad tie plate: C:0.19 | Mn:0.42 | P:0.005 | S:0.030 | Si::0.04 | Cu:0.24 | Cr:0.05 | Mo:0.009 | Ni:0.07 | Sn:0.011 | V: - | Nb: -
Truck leaf spring: C:0.57 | Mn:0.74 | P:0.010 | S:0.015 | Si:0.23 | Cu:0.25 | Cr:0.70 | Mo:0.02 | Ni:0.09 | Sn:0.008 | V:0.004 | Nb:0.070
Truck coil spring: C:0.58 | Mn:0.82 | P:0.018 | S:0.016 | Si:0.90 | Cu:0.01 | Cr:0.46 | Mo:0.01 | Ni:0.005 | Sn:0.002 | V:0.094 | Nb:0.007
Craftsman 3/4" Cold Chisel: C:0.36 | Mn:0.82 | P:0.012 | S:0.016 | Si:0.23 | Cu:0.10 | Cr:0.96 | Mo:0.025 | Ni:0.11 | Sn:0.010 | V:0.235
Grade 5 Nucor bolt, small n on top: C:0.35 | Mn:0.74 | S:0.02 | Si:0.23 | Cu:0.18 | Cr:0.10 | Mo:0.02 | Ni:0.07 | Sn:0.01 | V:0.003
Nucor Signpost. A-1 rail spec. C:0.72 | Mn:0.80 | P<0.030 | S<0.035 | Si:0.15 | Cu<0.50 | Cr<0.20 | Mo<0.06 | Ni< 0.20 | Sn<0.040
Grade 60 Rebar, C: 0.42 | Mn:1.05 | P<.040 | S<0.050 | Si:0.15 | Cu< 0.60 | Cr<0.30 | Mo<0.07 | Ni<0.25 | Sn<0.060 | V:0.005
Grade 40 Rebar, C: 0.28 | Mn:0.60 | P<.040 | S<0.050 | Si:0.15 | Cu< 0.60 | Cr<0.30 | Mo<0.07 | Ni<0.25 | Sn<0.060
These spikes were left along the tracks near my house. I noticed the new spike had markings on top MC, a number 6, and a monogram CO, I think.
Old Railroad Spike, no markings
C - 0.30
Mn - 0.80
Si - 0.25
Cu - 0.025
Cr - 0.10
Ni - 0.12
Sn - 0.02
V - 0.002
New Spike, Marked MC
C - 0.25
Mn - 1.00
Si - 0.23
Cu - 0.32
Cr - 0.10
Ni - 0.11
Sn - 0.02
V - 0.026 The major difference in the two, Vanadium makes it stronger without effecting the ductility of the metal much.
criteria for selection on page 11, also a good read on gm's sand vs lost foam
http://www.sfsa.org/tutorials/eng_block/GMBlock.pdf
Matweb list of Al cast alloys, all 380+ of them:
http://www.matweb.com/Search/MaterialGr ... roupID=208
Re: Composition of Metals
Really good post to have over here. Thanks jammer!!!
Return to “Metals and Alloys”
