Foam cutter - any ideas?
_FL_
Post by _FL_ »
Hi, I need to build a little foam cutter similar to a circular saw. The cut width should be adjustable. Does anybody have examples or links for that?
(Already tested the wire with transformer)
Re: Foam cutter - any ideas?
I have a few links, first, you can mount something like THIS TOOL to the bottom of a table with an adjustable fence.
But if your dead set on a hot wire table, I ALWAYS GO TO INSTRUCTABLES when Im trying to figure out how to make something.
_FL_
Post by _FL_ »
4cylndrfury wrote:But if your dead set on a hot wire table, I ALWAYS GO TO INSTRUCTABLES when Im trying to figure out how to make something.
Thank you very much! That´s the design I had in mind!
