Propeller plaque pattern
Posted: Sat Aug 13, 2011 6:35 pm
The Navy Loves Propellers, Screws in nautical terms, so I have several request for the "standard" Stylized screw plaque.
I used a technique I have not used Myself, so I will share
start at the lower left, and follow along clockwise
I carved a single blade of the propeller out of a piece of poplar. I glued it to a piece of ply, and wrapped that with tape and filled it with Aeromarine 125 silicone RTV rubber. and made a beautiful blue mold. I cast three blades using specialty resin model-pro. Work Fast this stuff gets hard quick at 90 degrees. you can slow it dowm a bit by keeping the 2 parts in the fridge to cool it.
In the past I have used the silicone calk and acrylic paint, and thinned bondo. I rescently ended up in the ER urinating blood. so I have went to the above products which are non toxic and all but odorless. . BTW the Bondo, or the fiberglass resin , or the combination of the two where the offending problem, the silicone. was just a pain to use compaired to real castable rubber
I made up a hub, and fitted it all together on a matchplate. Now I'm ready to Gate it, I would like to hear all your ideas on the best manner. I will start with one No Go. if you cast a real screw, you horn gate it into the hub. I'm not horn gating a plaque, now remember the leading edge of the screw is 3/8 IN thick, the trailing edge is 3/32IN. the hub is 1/2 IN thick with a hole half way through
