Page 3 of 5
Re: Makking patterns for a steam engine
Posted: Sat Jan 14, 2012 1:13 pm
by DavidF
Well Ive been making some more wood chips today, got a nice pile of them now. Also found this inside the chunk of wood i was spinning.
Still have a bit more to go on it but im making progress (unlike Jammer with that lathe i mailed him ) LOL couldnt resist.
Posted: Sat Jan 14, 2012 2:14 pm
DavidF wrote: Also found this inside the chunk of wood i was spinning.
Nice find
Posted: Sun Jan 15, 2012 11:46 am
by DavidF
and a little bit more progress, ugg yea im still saying 6 months for all the patterns and cores to be done......
Posted: Sun Jan 15, 2012 10:41 pm
Jammer has some great friends. Coming along on the patterns david... I can see parts in the near future.
Posted: Mon Jan 16, 2012 9:52 am
by 4cylndrfury
Looks great. What are your plans for filetting the corners? Bondo? Wax?
If this turns out, it could be a pretty cool kit. Good luck, and keep us posted
Posted: Mon Jan 16, 2012 10:42 am
by DavidF
I have had good luck with fillets using 5 min epoxy, most of the fillets are there from the turning and drafted at 2'. Once I attach the flange part it will go back in the lathe and be turned down for a 1' draft on the lower part of the flange and 2' on the upper then a fillet will be added to the bottom of the flange. Still waiting on my dang end mill so I can make up the core for the opening at the packing gland. Darn holidays.
Posted: Tue Jan 17, 2012 11:16 am
I like wax its easier to work with to me than bondo and doesn't make the mess bondo does, you need a certain size tool grab a ball bearing if you have one the right size silver solder it to a piece od tubing.
Posted: Tue Jan 17, 2012 12:43 pm
by 4cylndrfury
For what its worth, Ive had some success using Durhams Rock-Hard Water Putty - not as messy or smelly as bondo, and sets up faster - just mix with water to the desired consistency, and go
http://www.waterputty.com/
Posted: Tue Jan 17, 2012 5:10 pm
by DavidF
4cylndrfury wrote:For what its worth, Ive had some success using Durhams Rock-Hard Water Putty - not as messy or smelly as bondo, and sets up faster - just mix with water to the desired consistency, and go
Hmmm, that sounds like its worth a try. Ive been looking for a "simple" filler. Is it sandable?
Posted: Tue Jan 17, 2012 5:30 pm
Durams is sandable but as its name implies it does get hard. As a bonus it is cheap.
