yea, thats usually what I do, but the thing is, you need 8 cutters for a single DP of gears vs the method I was talking about which would do the whole set with one single cutter. It would take less time, and as long as it is kept sharp, it'll cut as many gears, no matter how many teeth you want to do with just one cutter. I was going to design my cutter that the tooth form would be replaceable so I could fit other DP gear cutters on it too to cut gears for other things too.
The one place I was at, I did single point cutting of teeth alot, just using a fly cutter but it defenitely took forever. If I had known about the hobbing method, I could have just made a single cutter and it would have saved alot of time in the long run, expecially how many gears I was making and fixing.
Anyways, I cant wait to see your shaper up and running and cutting stuff
