Hi Harry;
I have a bench or I should say I have a place to sit my moulds when I go to fill them with molten metal. Its a 10 foot long 2 feet wide piece of bar grate that I have sitting on top of two concrete blocks, my original intentions for the bar grate was a moulding bench, that may still happen. you can see part of it in the inserted photo.
I have it sitting with one end up against my big furnace the one I call the Blue Pig, why Blue Pig, cause its big fat and Blue. Its made from what is called a short 60 in the water well business. And when it gets hot it will eat anything from Peanut Shell's up to Cast Iron. It takes a little bit longer then the first furnace I made did to get hot but its made a lot heaver and its also bigger with it being able to I hope take up to a number 20 crucible, I don't have one that large to check with with. but its 18 inches deep with a 12 inch bore. I guess I should get a couple concrete blocks and put then by it for a step. I have to strech a little to pull my number 10 out when its full of iron.
And you are correct about it being a long way up from the ground, with the shot to hell section in my back any time I don't have to bend over is a relief.
As for as a pop up goes yea I could go buy me a canopy, but then I would probably go in the house and the thing would want to go visit with the nebighors or something, so its not worth it to me. I just wait till the shades in front of the shed and its cooled down a mite before I go outside and tinker. Its not like I have 50 orders waiting on castings that I need to pour but won't because it decided to be over 100 degrees again today.
The Blue Pig
The bench, part of me pour Cast Iron which is going to be a backplate for a 6 inch chuck.
And was I lucky the day I poured that back plate, you look at the photo and you will see that there is no weights on top of the flask to keep it from floating.
