Data Ive Accumulated...
Posted: Thu Sep 01, 2011 7:15 am
by 4cylndrfury
Here is a recipe sheet for making K-bond homemade oilbond sand based on the
Ray-vin foundry website...
Here is a good reference for those using or interested in using HVAC oil burners:
The Delavan Nozzle company spec sheet
Also, a huge reference tool is
The Casting Industry Suppliers Association
Im sure I have more, I just have to find it lol
Re: Data Ive Accumulated...
Posted: Sat Oct 15, 2011 8:56 am
4CF
could you all brand names or types to the recipe list that you posted for K-bond sand. like the type of oil, I use O'Reilly's Non Detergent 30 wt. along with Methanol Alcohol or whats commanly called racing fuel in Oklahoma, the other stuff Ethanol we call moonshine and drink it.
Posted: Wed Oct 19, 2011 12:55 pm
by 4cylndrfury
The Clay is Specifically
Bentone 34 manufactured by Elementis Specialties. The oil was
Penzoil marine grade 2 stroke oil. Catalyst is just Isopropyl alcohol from the drug store - I have been using the higher concentration - 91% IIRC - which will have less water in it. There has been talk that the water is what actually does the catalyzing, and the alcohol simply helps it disperse in the oil-ridden sand. So its possible that the 73% stuff might actually work better, but Ive done fine using what I have. I have also heard of people using methanol or HEAT engine treatment etc...but because these are alcohols too, I believe its the same thing going on as the isopropyl.
With regards to oil, I initially had found research that indicated that fully synthetic 2 stroke oil may be a good candidate for K-bond sand. Some people made mention of finding "base oils" from oil suppliers - this is oil with absolutely no additives - therefore less chemicals. From what I understand, the additives that are in most oils arent a danger to castings, but to casters - meaning they
MAY represent a health risk when the chemicals burn and are inhaled. In my opinion, there isnt going to be enough exposure on a hobbyist scale to represent a need to acquire these oils. The marine grade 2 stroke has been great for me, I am very happy with the resulting sand.
Posted: Wed Oct 19, 2011 1:21 pm
by Rocco
I've seen similar recipes that use Southern Clay Products
Tixogel EZ100 in place of the Bentone 34, the Tixogel is self activating like Petrobond II (i.e. it doesn't require a catalyst).
BTW Harry, what's the stuff you used to (still do?) sell?
Posted: Wed Oct 19, 2011 1:26 pm
by 4cylndrfury
Ive looked into Tixogel as well Rocco, but the distributor in SW Ohio was a jerk on the phone, so Bentone for now I guess. Really tho, Im thinking that in the long run, the premixed and premulled stuff from Retco Online may be the best bet for me. $60 fo 50lbs plus shipping is probably gonna be a better deal in the long run when you factor in how great the stuff works - comparing real petrobond vs Kbond that is. Looking at Harrys castings versus mine is a pretty good deciding factor on which is better. I think Im beginning to see why buying the premix is the best option if you dont have a muller and good sand to start with.
Posted: Wed Oct 19, 2011 2:55 pm
by Rocco
I hear what you're saying about the premix, I should put a bit more effort into finding a local supplier, there's got to be somebody around here that'll sell it to me for a reasonable price.
Posted: Sun Oct 23, 2011 8:52 am
4cylndrfury wrote:The Clay is Specifically
sorry for not answering sooner, but got sort of busy at work and with driving to new mexico and what not, Thanks for the type of oil that you are using, I thing that harry was using the same type when he was mixing his own.
I have bought powder from both Harry and Retco I also purchased the cat from Retco when I first started mixing my own oil bonded sand, I have used both a 100 grain silica sand and a play box sand that are both bagged and sold by Quikrete thru distrubitors. The Play box sand is on the coarse side but leaves an excellent finish as far as I am concerned. the Silica sand leaves a much finer finish which would be preferred if casting art or parts that were to be plated as the finer finish would leave less polishing before plating.
I have found a supplier in Minniapolis for petrobond 1 and 2 powder plus another one in Lufkin texas. they will both ship by truck but this does drive the cost of the product up by almost if not more than 50 percent. Sand I guess I am lucky in that I have a supplier here local in OKC for the fine grain silica sand from Quickrete. plus I have found a souce in Gainesville Texas that bags sand for United Silica that handles silica cans up to a 225 mesh. that will sell in bags fro 50 to 3000 pounds, just depends on how much you need. the local sand here in Oklahoma also has a high silica content to it and one day I plan on mixing up a small batch of some from the river and see what happens.
Another source for sand that i have located is in kansas and is a river sand that is classified as stove plate sand from Johnson county on eastern kansas if someone was to live in this area they might want to look up Kansas Brass Caster on the old Lionel's Labs site this is the sand that he uses. if asked he may provide information on where this sand can be aquired from. I am sure that people over look a lot of resources in their own backyard's so to speak for sand.
I will try to locate some of the Penn 2 stroke oil, I have been using O'Rielly's 30wt Non Detergent in my sand.
If your interested in building a muller I can supply pictures of mine if you want I really didn't use any set measurements when building it, I kinda followed Steve Chastians book but didn't lock myself into doing every thing that he did. My drive is open and cost a lot less then his did.
I am hoping that the boss will send me to either Minnesota or to lufkin texas if he does I will differently have to stop and pick up a bag of petrobond 2 powder.
Posted: Sun Oct 23, 2011 10:16 am
The oil I was using when I was mixing my own sand was sold as Outboard Motor oil and I found it at both Walmart and Kragen.
On the Petrobond 2, it says that you do not need to use cat with it but I have also read where people still do use it.
