The thing is I have cut the same thing about 8 to 10 times now, from full size down to 25% and it has been the same
I am thinking it maybe the code might be the problem. I had Cxevalo do the code for me, He did not test it. So I am not blaming him.
I would love to know how to do a drawing like that so I can make my own in the future. I have 2D/ 3D cad (Design Cad 3D max 16) I know how to use it in 2D as I use all the time for house plans...But when it comes to the 3D part I'm a bit lost on how to start.
What do you cut most of your parts out of???
Here is a pic of some of the other parts that make up the other castings for the cart.
- The back axle before I gave it the chop
- IMG_2275fd.jpg (123.6 KiB) Viewed 9809 times
I didn't like the square bits where the axle will go through so I gave it the chop and added some round bits.
I'm not sure how these parts will ram up, Imay need to cut them down the middle to make a 2 part pattern.
- All the parts after adding the round bits
- IMG_2279fd.jpg (136.63 KiB) Viewed 9809 times
I will be making a new base because I mis measured one of the parts, but this is how the cast parts will sit once done.
- How the parts fit on the base
- IMG_2276fd.jpg (126.11 KiB) Viewed 9809 times
Im still not sure if I will cast these bits in Aluminium then paint it or in bronze like the rest of the engine and leave it as is
What do you think
