wood lath
Re: wood lath
I was out most of the day today so not much got done, I just need to bolt the frame to the lathe, then dyna bolt the lot to the floor and it should be good to go :D
Re: wood lath
All up and running :D
Re: wood lath
Nice Mike, you are moving along nicely in tooling up.
Re: wood lath
First try, mmmmmm I like the shape also, looks sorta like one of those things that go BANG :D
barryjyoung
Re: wood lath
Post by barryjyoung »
Hi Harry:
It is a terrible myth that anything is harder on a CNC than on a conventional machine. CNC's have a digital readout for each axis, and have variable speed power feed. The very best conventional machines have CNC controls attached. There is nothing that a conventional machine does that a CNC machine cannot do better, including manual machining. You have to do the same setup on a conventional machine that you have to do on a CNC used conventionally. The CNC allows you to also do MDI commands that act like little programs you put in right at the machine. You are absolutely correct in the second half of your statement, you can easily and quickly move any axis a tiny amount, or a large amount.
Good luck all.
Barry
