Molding sand grain size
I was curious about the mesh size of my sand so I took a pinch and squeezed it in my micrometer. Several tries came out with the same 0.008" so I looked it up and that is 70 mesh. What are you guys getting on grain size?
Re: Molding sand grain size
Wow thats about .2 mm, my play sand is about .8mm and under, thats what the supplier to the hardware store were I get it told me. I'm starting to add a finer sand from a landscape supplier to my mix, I'll take some to work tonight and see if i can measure it, my micrometer has a round anvil so it would be damn difficult to measure
wikisi
Post by wikisi »
I use 70 mesh olivine sand. I get it from a local foundry. I asked if I could buy a few buckets full, the guy said you bring the buckets you can have the sand free, he even gave me a tour 8-) Great guy!
I measured mine at work last night and I got .5mm on my play sand and the new stuff .3mm
I think I might go and measure mine! :)
Mine is 0.35mm I checked it 3 times just to be sure :)
davidbraley
Post by davidbraley »
What are these millimeters you speak of! That's not a real measuring system! :D
Just kidding. :roll:
Here's an even better site with info on this mysterious "Mesh" measuring system:
http://en.wikipedia.org/wiki/Mesh_%28scale%29
-David
_FL_
Post by _FL_ »
Just saw the technical specs of my greensand recently: Average grain size: 0,09mm. Wow! Petrobond Goodbye.
I did not think such a small grain size was a good thing for greensand because of the need to vent steam through the sand. That is 0.003" which is nearly 1/3 rd the size I measured in mine. If it works though I say go for it, I am sure someone has figured out how to get good binding with very little water.
