Here is the drag ready for ramming. note that stack flasks have the pins pointing upwards from below
Here is the completed drag
Here you can see a cheek, you can use multiple cheeks. 4 being common. the only difference between the drag and the cheeks, is each cheek must have a sprue cut
Here is the drag and the lower cheek complete and on the deck
here is the cope ready to go on,
Here is the entire mold
I intended to make 4 sections, that is why there is no labeled cope, but I ran out of metal one piece shy
Here we have the resulting castings.
There was one neat thing that I did not think of, the heavy 1/4 inch steel flasks did not raise when being rammed, A problem I have alot, so I did not have to clamp the pattern to the flask while I rammed... Hope this helps a few of you out
