My idea is to use a propane tank for the shell, order some kanthal elements, some sort of automatic temperature control that I can select the heat. Thermocouple/LCD readout. I'll clean this thread up later and add pictures as i find things I want to do
Things I need to get:
Propane tank Shell
Insulated Fire Brick Locally 2.50 a brick.
Kanthal element
Some Type of High temp paint
Thermostat
Temperature Gauge (LCD/Analong, dont care really)
High temp Cord and Connections
I read these Insulated fire bricks can be cut with a skill saw, table saw, other method of sawing but more time is required. I'm not sure what the exact specs are so im not sure if they are hard brick or not.
