The shell is a water expansion tank from a hot water heater. I want to say it was about 13" or so across - found it on the side of the road = Free!
Cut open and legs attached with sheet metal screws. Legs were leftover from a garage door kit = free:
A styrofoam plug for the drain:
Foamed castable in the floor:
half inch hotface on the floor:
1 inch strips of ceramic fiber board insulation:
inner form installed, and 2" PVC tuyere form installed:
1" hotface cast:
And the final result is an 11 inch bore, and a 16" depth
I currntly use a section of ceramic board coated in refractory to hold the fibers together for a lid. I need to get cracking on a real lid with a lifting mechanism...lifting the lid with gloved hands is often...uncomfortable. The refractory is chicago firebrick dense alumina castable - got the torn bag free from the remnants bin at a boiler installation place. Same with the ceramic board - corner was broken off and they just wanted to get rid of it.
So this furnace with real castable refractory and ceramic insulation was totally free. A little scrounging can go a long way
