Coaster Project
Re: Coaster Project
On one I rounded all 4 points and on the other just the bottom points. I don't know which I like better, what do you think?
Re: Coaster Project
The one on the left looks great Jerry
Re: Coaster Project
I tried to do the finish cut on these hearts yesterday and the wood I got isn't working out. It wants to chip out and mess everything up. I've got a different wood to try today and I'll see how it does.
Mike, I'm assuming this is going to be a "one of" casting on these, or are you going to be making a bunch of them?
Re: Coaster Project
Jammer wrote:I tried to do the finish cut on these hearts yesterday and the wood I got isn't working out. It wants to chip out and mess everything up. I've got a different wood to try today and I'll see how it does.
The heart ones should be just a one of, I would expect there will be a few of the other ones made
Re: Coaster Project
use a plastic cutting board, I used plastic on most of the limit switch mounts for the router I'm building.
and they are cheap
also MDF it won't chip, but makes a butt load of dust. the pattern for the handle that I cast the other day was done in MDF
Re: Coaster Project
I tried a cutting board, it was Polypropylene. It just melted and wrapped around the bit. I'm running at 30,000 rpm and don't have an adjustment. I'm concerned that the router is just a piece of junk and I'm getting some wobble. I ran the hearts yesterday with the Basswood and it just chipped out the letters pretty bad. I thought a piece of the engineered flooring would work but it's like pressed paper and just tears out. I would like to try some Corian but I don't know where to get any quickly. I would need to send these to Mike in the next week so he can cast them.
I had some trouble with the patterns, bad curves on the hearts, wrong cuts and just general aggravations. I thought the cut would be easy.
Re: Coaster Project
Jammer wrote:I tried a cutting board, it was Polypropylene. It just melted and wrapped around the bit. I'm running at 30,000 rpm and don't have an adjustment. I'm concerned that the router is just a piece of junk and I'm getting some wobble. I ran the hearts yesterday with the Basswood and it just chipped out the letters pretty bad. I thought a piece of the engineered flooring would work but it's like pressed paper and just tears out. I would like to try some Corian but I don't know where to get any quickly. I would need to send these to Mike in the next week so he can cast them.
Did you try MDF Jerry
Re: Coaster Project
make friends with shop that does counter tops they always have bits and pieces. I've got some plastic bars but not big enough to cut what your doing or I'd send you one they are like 16 inchs long. I took some 12 inch PVC pipe and heated it in the oven and flattened it out by sitting a bunch of weight on top of it till it got cold, it machined pretty nice.
sound like wobble if your turning the bit that fast, it should cut with no problems at all.
I'm fixing to have to buy a router for my table I got the last screw today. thinking about the Makita its a C note at HD but like they say you get what you pay for.
Re: Coaster Project
If the time runs out Jerry, that's ok I'm not pushing. I'd rather wait then having you rushing about thinking your running out of time
Re: Coaster Project
I've got something I thought was MDF, I think it's just particle board. It doesn't hold together very well, but works pretty good for larger stuff. I just thought it would be a piece of cake, I'm just getting agitated. We're going away tomorrow, the guys are going to try another Iron Pour in Alabama. I'm going to stop a couple places to see if I can find something to try.
