Buckle pattern
Re: Buckle pattern
Harry wrote:As long as they dont drop off the map those half dozen patterns could become masters for hundreds of casters around the world.
Could'nt agree more Harry
Trev you must have been up late last night, I received your massage a 1.30 am on my iphone, I had to be up as I was on night shift. Wish someone would stopped this shift work roller-coaster that I'm on :roll: so I've slept all day and have woken up feeling like I've stepped out onto the road and have been hit by a fnkn big bus, I feel like crap, funny thing is when I step into my ute to go to work the body just seams to click into gear, brain switches on and its all good till a bout 3 am, that's when my body batteries are just about spent :?
bunyip
Re: Buckle pattern
Post by bunyip »
First, Mike when I'm done I will return it to you.It shall probably be a couple of weeks,one thing with you'r address though, is the last number of you'r PO box number 2 or 7 ? Harry, hello; at this stage I do plan to investment cast however many I end up casting & yes had already planned to change the hook into a straight wire like prong with a bulb on the end.Won't be spin casting but probably steam cast. Cheers Trev.
On top down under
Re: Buckle pattern
No rush Trev ,when your ready will do just fine. Last number on my post box is 2
Re: Buckle pattern
bunyip wrote:First, Mike when I'm done I will return it to you.It shall probably be a couple of weeks,one thing with you'r address though, is the last number of you'r PO box number 2 or 7 ? Harry, hello; at this stage I do plan to investment cast however many I end up casting & yes had already planned to change the hook into a straight wire like prong with a bulb on the end.Won't be spin casting but probably steam cast. Cheers Trev.
Lots of pictures!! Been a while since I've seen a good steam cast video!
Re: Buckle pattern
Have you got the pattern back yet Mike?
I dont need it, I just dont want to see it get lost!
Re: Buckle pattern
Nudge wrote:Have you got the pattern back yet Mike?
Hi Nudge, yes I have it back and its gone out to wiifm from the other forum to play with
Re: Buckle pattern
Sweet as, as long as someone knows where it is! :)
