nope no investments, although I do have the stuff, but the one time I used it well lets just say that it didn't turn out very good.
the sand that I have mixed up is pretty fine, plus I have been trying to pour a lot colder then I used to which helps with the surface finish anyway it helps with my castings.
Problem with this project I that I have it all together and it won't pump the lube that I put in it, but the stuff is pretty stiff so I may have to round up the stuff to make a hot plate to mount it on, like they do the commercial ones.
I seem to always cast too hot. I think I had a cold pour early on and now I over do it.
Yeah, when I cooled down my Everdur pours I have had much better surface finishes. I used to heat it to 2300 F. and rush the pour. Now I pull it at around 2150 F. and take my time. I figure it's going in at about 2000 F.
Charlie said he wanted a scalping knife for use on the gophers he hunts, so we decided to make him one
That look cool Dave, how was it shaped
shaped with a belt grinder and mill bastard file to draw file it down flat. cut to shape on a band saw
now I just need to get some dies for it. finally got the contraption to pump the lube today,
https://drive.google.com/file/d/0B7TyAe ... sp=sharing
made a new nut for the lube sizer today, there is a couple more pieces that I need to make to pressure feed system so that I can increase the pressure on the spring inside the tube. I circled the new part in red.
needed a big thick hunk of aluminum for a hot shoe for the lubersizer so I casted one this morning.
also caught the shop monster slacking on the job
and the block in place, now to get some electrics hooked up to it
sometimes mother nature smiles for me, instead of just raining death, destruction, and tornados on everyone
