Da Queen
Re: Da Queen
Rasper wrote:I finished welding on the Queen's head. It was a bit difficult. Using a borax flux I get a bright orange flare that keeps me from seeing the puddle very well. I have a lens that I use for gas welding aluminum at my California shop that filters out that orange light, but it cost 187 dollars so I am not going to be buying another one. I just added a lot of filler rod so I would be sure to have enough build up. Then I cut it off with a chisel. Time consuming, but it's better than having to re-weld. Welding this stuff takes a lot of time—and propane gas. I have to heat the entire casting to somewhere near dull red with a propane burner in order to weld it. This bronze conducts heat like you wouldn't believe.
Your a very skilled individual Richard, I just love your work
Re: Da Queen
Thank you Sir.
bunyip
Re: Da Queen
Post by bunyip »
Love this piece Richard. A couple of questions; roughly what are the dimensions of this sculpture & why did you cast in 2 pieces, was this because of size limits with you'r burnout kiln ? Cheers Trev.
On top down under
Re: Da Queen
This was the fifth time I cast her. I had problems getting the moisture and the wax residue burned out of the core when I cast her whole. Things like this happened.
She is 18 (46 cm) inches high. Her head is 7 (18 cm) inches tall.
bunyip
Re: Da Queen
Post by bunyip »
Thanks for the info Richard. Viewing you'r last picture I can certainly see the drama you were having as a 1 piece casting & am so happy for you as you'r persistence paid off big time. She's gorgeous. Cheers Trev.
On top down under
Re: Da Queen
I poured a test casting of the head dress of an Egyptian Queen I am doing. Why a test? I put many hours of work into chasing the wax that I will use for the real cast. I made another wax without the detail to test with.
Good thing I did. The way I gated it there was no feed into the tail feathers, which inadvertently I had made the thickest part of the wax.There were only vents. There was some shrinkage there. Everything that the tail feathers could have drawn metal from had frozen, so it shrank.
Other than that it is perfect. I will add a gate to the tail and pour the real crown now.
I normally change out the bricks in the kiln base every couple of burn outs. I went too long this time. Globs of melted bricks partially closed off the flame tunnel and I couldn't get the burn out hot enough. It worked, but just barely. I need to make a burner tunnel from Mizzou.
Re: Da Queen
looking good. but I do have to say that I like the bald look she has with no hair or helmet. you put a ton of work in that helmet hope the pour turns out ok.
Re: Da Queen
You are right on Dave. I like her bald too. I think she has a lovely head. I am very seriously considering having the crown be a separate sculpture entirely, and leaving her bald.
Re: Da Queen
Rasper wrote:You are right on Dave. I like her bald too. I think she has a lovely head. I am very seriously considering having the crown be a separate sculpture entirely, and leaving her bald.
wish my talents bent to the artistic but sadly they don't, be nice to be able to do that type of stuff guy could make an extra dollar from time to time.
Re: Da Queen
I put her head dress on her today to take a look. Damn if i don't like it.
