First order of business was that last night when I rammed it back up I cut the slope way out like three inches this helped but I didn't cut down the side deep enough as you will see.
Second the part poured full no problems there I vented both ends on 3/32 vent in tip of the handle and two one on each side of the steel square.
I also moved where I had been cutting the gate, I have been cutting it in to the flange where the square hole is needed. I moved it up into the body of the handle this got rid of the bubble, but I had a small shrink in the handle like the big end pulled metal to it faster then the sprue could feed it, the runner was 3/4 by a good 1/2 inch deep.
To remove the square peg I had to drill a hole in the handle so if I do another one I will drill a hole in the square bar so that I can insert a pin long enough that it will stick out the top of the handle and cast it in the steel this way I can drive the thing out with out messing up the finish, I also need to cut down the side deeper to get rid of the edge breaking off of he mold. not a big thing but it I had to make a hundred of these, clean up time. I may of pour way too hot, I let the furnace get overly hot while trying to melt a big hunk of FORD Wheel one of them thats got all the plastic on them that shine so nice, scratch the plastic and pay 400.00 bucks for a new one or better.
of the two handles laying on the flask the one in the back is the first one I did, the short one in from is the one with the big hole in it and the short pour.
