Band saws
Band saws
Hi all, I want to buy a band saw and I cannot decide what type I should get, I can not decide between these two https://www.machineryhouse.com.au/Produ ... 4202#specs or one Simla to this one http://www.ebay.com.au/itm/RYOBI-BAND-S ... 3cb95cff48 I need some advice :)
davidbraley
Re: Band saws
Post by davidbraley »
So based on the two models you show, you are only cutting wood? The first model looks to be a lot more heavy duty than the second (ryobi). Do you have to buy a new one? You will always get a lot more machine if you buy it used.
-David
Re: Band saws
Hi Mike
if it was me I would get the one that would be the easiest to get spare parts for
blindpig
Re: Band saws
Post by blindpig »
Hey Mike,
I don't know if you'd be interested but thought I'd share this guys site. He's built quite a bandsaw ,among other machines.Really looks interesting to me.
You might check it out woodgears.ca/bandsaw/build html
Don
Re: Band saws
That looks cool. I may even just settle for a good guilty jig saw yet , then I can keep some funds to buy a drill mill
Re: Band saws
Well I've decided to try for a jig saw then the next thing will be a mill of some description. My brother that lives in Sydney and is a member of the Yamaha XS 650 Club of Australia http://www.xs650.org.au/ has asked me if I can cast some parts, starting with a sump extension such as in the photo below And they will need a milled surface sooooo I need a mill. My brother will then sell them through his club
Plus his mate races a xs 650 and wants me to cast a few lighter parts out of aluminum such as the foot peg hangers in the second
Re: Band saws
Get the jig saw then the mill, when you are looking for a mill get one with a dovetail not a round post for the piller. It will save a lot of grief later. :roll: ask me I know :oops:
Re: Band saws
Nudge wrote:Get the jig saw then the mill, when you are looking for a mill get one with a dovetail not a round post for the piller. It will save a lot of grief later. :roll: ask me I know :oops:
This the one I was looking at http://www.shawmachinery.com.au/UsedEqu ... html#Mills whats wrong with the round post nudge
Re: Band saws
the head is hard to keep aligned with the Y azis. also make sure when you get a mill that you get one with an R8 spindle. you will have to buy the same amount of tooling to use a R8 spindle but, if and when you upgrade to a larger mill, your tooling will follow, meaning that you can go from a bench top to a Bridgeport clone, or true Bridgeport without having to retool from a morse taper spindle
Re: Band saws
Nice score on the casting work. That is the kind of word of mouth stuff thats starts you on your way to having people look you up when they want something made.
