CNC Fun
CNC Fun
Well, I finally picked up an X box 360 controller. I watched the video on plugging it into the Mach 3. Looks fairly easy so I'll give it a go tomorrow or this weekend. If I have any trouble, I'll give you a call Dave.
Re: CNC Fun
sure, if you need my number just holler, I had to go in to the mill file and hard code the thing in to get mine to work, I'll fire up that computer and find the file so I know what to talk about.
Re: CNC Fun
Hey, it works!! Failed a couple times, but I re-read the instructions and I didn't have the software for the controller. As soon as I loaded it then it worked fine. Now I'll make a touch pad to set the z axis
Re: CNC Fun
I need to drag mine out in the middle of the dinning room and cut something with it.
Re: CNC Fun
I've been working on this most of the summer. I sure cut up a bunch of foam board. This is about version #8. It's for a hornless anvil. I have a piece of 3/8" thick tool steel for the top, I still need to cut a hardy hole in it and make the core for the hole. It should weigh about 100# in cast iron and the top will be 4" by 10". I hope to cast it at Sloss Furnace in Birmingham, Al.
Re: CNC Fun
THAT LOOKS FANTASTIC!!
Re: CNC Fun
I'm starting to get it figured out. I need to bite the bullet and buy something like Pro-Carve or Vectric or something. Rhino-CAM is too expensive.
I did a grave marker the other day, I'll get some pics put on.
Re: CNC Fun
I'd make the steel plate for the top out of 1 inch that much cast iron on top of a 3/8 plate will pretty much melt it.
I need to get my router up and running now that I've just about finished the CAD stuff for the slotter I've been working on.
Re: CNC Fun
I think I need to put my high speed router motor back on. I tried to cut some MDF and it just wants to chip it out and burn. I've cut it before with the router and no problems. I want to find a denser MDF also. I'm trying to make a mold to try some foundry letters with lead or pewter. All caps and about 3/4" tall.
Re: CNC Fun
They make a HD fiberboard in 1/4" thickness. I've used that often for pattern faces making plaques, etc.
