Alloy rocker cover
Re: Alloy rocker cover
F.C. wrote:Your sand structure looks excessively grainy. I see massive amounts of light colored bits in it. What is that? What is your sand mix composed of? Further, those three hooks won't serve to keep that sand mass intact with the upper half of that mold. The hooks are too thick, and, what you do utilize for rebar reinforcement needs to be thin and attached to a structural support within the upper half of that mold frame. I'll see about finding you an example pic, if not, I'll sketch you what I'm talking about.
Thanks Frank
The sand is the finest that I could find at 80 mesh, this is the supplier http://www.riversideindustrialsands.com ... ndry-sand/ . The white bits are new molding sand that I made a few weeks back. the mix is 10 % bentnite and two % corn flour, next batch that I make I'll do your mix 5% bentnite and 5 % corn flour
What a useless fucked up day to day was, I had to do a days training at work today, 7 hour of useless shit that big business try to ram down your throat, just to give them a warm fuzzy feeling :x
mite5255 wrote:What a useless fucked up day to day was, I had to do a days training at work today, 7 hour of useless shit that big business try to ram down your throat, just to give them a warm fuzzy feeling :x
Obviously sensitivity training... :lol:
nothing a couple of cold ones won't fix. used to have them days myself.
I'm hoping to get a start on this soon, I have everything ready but its been damn hot here, and every time I suggest to the wife that I'm going to do some casting she starts going on about the heat and at my age I should be more careful, it's 10 am and its 38 c already( 100.4f,for the people that don't understand the simpler modern measuring system :lol: )
understand that 165 C equals about 300 F or it used to when I worked on asphalt plants.
bunyip
Post by bunyip »
Another peice of useless information ; with faranheit scale & centigrade scale meet each other at minus 40 deg.
On top down under
Mite have you made any progress on this
dallen wrote:Mite have you made any progress on this
Short answer Dave no, its been very hot here, so all casting is on hold till the weather cool and the humidity drops.....I've made the flasks and they are going to be very heavy full of packed sand, so I'll also need to find a way to handle them
Slacker.....
I remember the year we had 100 plus temps for like almost three months,
me I would be wanting the weather to cool and the humidity to go up as in rain so the fire danger will drop like a rock in a barrel of water.
rig you up some sort of lift, I made me a swing arm with a boat wench on it so as to handle large flasks and curcibles if need be like the flat belt pulley that I made last fall. that whole mold weighted well over 300 pounds.
