digital temperature
From Crucibles to Tongs to Pyrometers, the Tools on the Foundry Floor.
digital temperature
I just snagged this out of evil bay for the paltry sum of with shipping 47 dollars.
Re: digital temperature
Do you know what the max temp rating is? I've got one similar to that but it only goes to 999 F. I've only used it for lead.
Rocco
Post by Rocco »
Personally, I like like this kind of device instead. It's a little more versatile, not only does it display the temperature you can also use it for thermostatic control, have a wide temperature range and can be programmed to accept input from a wide variety of temperature sensors and thermocouples. Devices like this are on ebay all the time for about $30 +shipping. If anyone's interested in something like this, just search ebay for the term "PID temperature controller". And if you're interested in building an electric kiln or furnace and would like to be able to control the rate at which it heats up or cools down search for a "ramp soak controller". Ramp/soak controllers currently cost $80-90 + shipping pretty good value for money imo.
got two of em, with one of them having a RS485 option on it so I can hook it to my laptop for programming instead of having to push little buttons.
returned home this morning from having some really bad coffee at the local choke and puke, to find two boxes sitting on my front porch, one had the digital thermometer in it, so I politely hooked up a thermal couple to it and stuck it in the flame of the cookstove let the reading run up till it hit 1100 degrees, that should be good enough to say the thing will work up to 2250 I belive is where K type thermal couple flake out at. So now to make a tube to put that nice hefty thermal couple that I got from Mifco into. anyone used the lance probes from Mifco things got like a 5/8" diameter graphite end about 8 inches long on it. I know aluminum won't hurt it brass and bronze I wouldn't think would, Cast Iron MIGHT, so need some pointers.
I've been using one of those Mifco probes in bronze to 2300F and it's holding up great.
I use a $4.95 Harbor Freight multimeter. That works great too. I did buy two of them. After all it is Harbor Freight.
And you want to be careful about those ceramic sheaths. The ones I have seen are for using in a furnace or kiln where the temperature rises gradually. To stick it in a pot of molten metal, even after pre-heating it, would be too much of a thermal shock. Don't ask me how I know.
R
