Should be challenging. I'll try to post updates as I work on them.
Not another Whovian??
Coaster Project
Coaster Project
- Attachments
- logo.png (9.6 KiB) Viewed 11313 times
- cordrey mite logo.png (29.69 KiB) Viewed 11313 times
Re: I've got the CNC running
Nothing quite like a good challenge lolJammer wrote:Should be challenging. I'll try to post updates as I work on them.
Any issues just let me know, plus no rush
Not me Jerry, but my youngest Brother is and so is his son, when I get the pattern and make some I'll then post them on my facebook, they both should go nuts and want some lol
Re: Coaster Project
Started playing with this while it's snowing. I've got a couple pictures worked out to start the g-code.
Re: Coaster Project
Looking great Jerry, on the copper one could you put McDermontt Avaition in a semi circle across the top and heli-lift Australia in a semi circle across the bottom, that's if there is room and if it all looks symmetricalJammer wrote:Started playing with this while it's snowing. I've got a couple pictures worked out to start the g-code.
Thanks Jerry
Re: Coaster Project
Yea Mike, that's the inside circle. I'm going to put an out side circle around it and put the lettering between the two. We'll see how it looks. Would you want it say anything in the outside of the school coaster? Teacher's name, Number 1 teacher...whatever. Or it could be a little larger with a small rim on the outside edge...?
Re: Coaster Project
Just so it fits the whole coaster Jerry, but hey I'm open to ideas, right at this moment I need sleep I finish night-shift at 07-00 and was in bed by 08-30, its 13-20 so I'm heading back to bed, I'm stuffedJammer wrote:Yea Mike, that's the inside circle. I'm going to put an out side circle around it and put the lettering between the two. We'll see how it looks. Would you want it say anything in the outside of the school coaster? Teacher's name, Number 1 teacher...whatever. Or it could be a little larger with a small rim on the outside edge...?
Re: Coaster Project
Just a bit larger on the school on Jerry if you can Jerry with the edgeJammer wrote:Yea Mike, that's the inside circle. I'm going to put an out side circle around it and put the lettering between the two. We'll see how it looks. Would you want it say anything in the outside of the school coaster? Teacher's name, Number 1 teacher...whatever. Or it could be a little larger with a small rim on the outside edge...?
Re: Coaster Project
Here's a couple more Pictures. I wish I could post the complete set up, everything is in G-code in parts and pieces.
I need to upload the Inkscape program to see what it will look like before putting it in the CNC machine.
Picture the McDermott Aviation and Heli-Lift Australia in the black ring, raised letters with the background cleaned up.
The way I'm planning on cutting it, the black lines and areas will be the high points and the white will be lowered.
- Attachments
- tardis.jpg (37.83 KiB) Viewed 11252 times
- cooroy.jpg (77.54 KiB) Viewed 11252 times
- aus.jpg (30.16 KiB) Viewed 11252 times
Re: Coaster Project
That looks fantastic Jerry, they should look greatJammer wrote:Here's a couple more Pictures. I wish I could post the complete set up, everything is in G-code in parts and pieces.
Re: Coaster Project
I don't know why some of the edges are fuzzy, it appears to be just on the pictures. The CNC ignores some of the small pixels or a lot of them if the setting it too high.
I was hoping for a cricky, Krikey ... what ever the word is?
