Rasper's steps for alloying Silicon Bronze.
Alloys and alloying your own
Silicon Bronze Ingot CDA 873 - Everdur
Composition Nominal
Copper 95
Silicon 4
Manganese 1
Physical Properties
Melting Point (Liquidus) 1790F
Melting Point (Solidus) 1590F
Pouring Temperature (Light) 2000-2150F
Pouring Temperature (Heavy) 1850-1950F
Density .302 lb/cu. in.
I melt a 1/3 crucible of Everdur and then start adding the copper to that and push it under the surface immediately to prevent air contact. After the crucible is 2/3 full I add some silicon and manganese. Then I add the remaining copper and then the remaining silicon and manganese.I let it sit for a few minutes and add some borax to the center of the melt and stir a bit with a steel rod. Then I pour it into ingots. I still get some dross doing it this way. The borax eliminates some of it.
The whole process takes maybe 20 minutes.
Re: Rasper's steps for alloying Silicon Bronze.
Jammer wrote:Silicon Bronze Ingot CDA 873 - Everdur
Composition Nominal
Copper 95
Silicon 4
Manganese 1
Physical Properties
Hi Jerry, What thickness would you call thin
Not sure mike, I got the chemistry from the net and this is Rasper's explanation on alloying. Maybe Richard will chime in, but I imagine that 2 to 4 mm would need to be pretty hot. It would also depend on the area. If you were casting a thin belt buckle or a large thin plaque. Taking into account how long it's going to take to fill the mold.
I pour my sculptures at between 3/16 and 1/4 inch thick (in Ozspeak between 5 and 6.5 mm). I pour at around 2000 F. (1100 Centigrade). Remember though that I am pouring into a mold that is hot (somewhere around 800 F. (425 centigrade). I am also limited by the mold composition: plaster does not behave well when metal over 2000 F. is poured into it. It causes surface problems such as this:
What you want is to pour bronze just hot enough to fill the mold completely. How does one determine that? By experience mostly. (That's code for making mistakes.)
Rasper wrote:I pour my sculptures at between 3/16 and 1/4 inch thick (in Ozspeak between 5 and 6.5 mm). I pour at around 2000 F. (1100 Centigrade). Remember though that I am pouring into a mold that is hot (somewhere around 800 F. (425 centigrade). I am also limited by the mold composition: plaster does not behave well when metal over 2000 F. is poured into it. It causes surface problems such as this:
Thanks Richards, I do disagree with one statement tho, we don't make mistakes, we have learning experiences ;) ;) :) :)
Return to “Alloy Discussions”
