A New Girl In the Works
Creations to please the eye, where form trumps over function.
Re: A New Girl In the Works
is the brown coating on the girl silicone
It's polyurethane. I use Reo Flex, made by Smooth-On. It's about half the price of silicone. Other than the powerful fumes, and the fact that it sticks to everything and needs a release agent, I find it just as good as silicone for my purposes. I use silicone for small intricate things.
Hi Richard, is the Reo Flex durable enough to get repeat wax castings, I'm also assuming it is not affected by uv rays. I have some resin Buddha's and some other small statues that I would like to copy in bronze or aluminum using lost wax.
I have done a fail amount of mold making in the past but using latex rubber for making garden ornaments in concrete
Reo Flex RTV (Room Temperature Vulcanizing ) polyurethane rubber is unbelievably tough stuff. Should be good for at ;east a hundred wax castings.
I'll give it a go :)
What I have been doing is this:
I can only get the reo Flex 30 and the Reo Flex 50 in Mexico City. I have been buying the 30. The 30 is too runny for brushing on, so I thicken it a little with Cab-O-Sil for the first coat, and even more for the next coats.
I plan to try the 50 for the thicker coats. Using only the 30 works, but I would like the later coats to be more like a paste.
Also Smooth-On makes a polyurethane called "Brush-On" which I used once. It is thick and eliminates the sagging off problem, but to use it as a first and second coat on oil based clay is a little dangerous to the clay as I needed to press on the brush to fill in the details. Maybe two coats of thickened 30 and then "Brush-On" for the rest of the build up would be a good way to go.
Smooth-On has a distributor in Oz:
Rowe Trading
4 Holder Ave.
Richmond
South Australia 5033
Tel: 61-8-8234-0000
Fax: 61-8-8234-2092
fwoods@rowetrading.com.au sales@rowetrading.com.au
http://www.rowetrading.com.au/
Thanks for that Richard :) , I'll get in contact with them next week. I'm also assuming the higher the number the thicker it is?
I think so. I haven't run a test. The number is a measure of the hardness of the cured rubber on the Shore scale, hence the flexibility of the cured mold.
To thicken the rubber for brushing on I use Cab-O-Sil which is fumed silica and which Smooth-On sells as Ure-Fil 9. They also sell Ure-Fil 11, which they say is good for thickening Reo-Flex for brush on applications.
The New Girl has a mother mold.
Looks great Richard :) . what you call the mother mold, I have always called it the mold keeper, anyway that's how my father always referred to it while teaching me molding with latex rubber.
What are those protrusions through the plaster for?
