then this morning I used it to cut the keyway in the pulley that I made, still have to make a woodruff key of cut a straight keyway in the shaft probably make a new woodruff key so I can keep the shaft original.
And I took the transmission apart and swapped the shafts so that I could lay the thing down horizontal instead of having it standing up vertical. going to redo the engine mount and have it on top like is in the picture.
Latz I'll probably make it with wood but it will be split on the horizontal plane to make it easy to ram up. I do plan on casting the recess in it plus after some armchair engineering this morning I'm going to have the hub stick out the back about an inch which will give me more on the shaft, flanges will be casted on, this is a cake walk pattern to make after the other one. Just have to figure out if I want to eat up a bunch of maple to make it with our use some 2X stuff thats laying around. will redo the drawing to reflect the changes I'm thinking about. also I'm thinking of making it 5 inches instead of 6 in diameter.
